Connector threaded male for kitchen tap
3 Oct 2007
Sussex
I cannot believe I am asking this question.
I am going to connect a monobloc tap to the kitchen sink which I am going to install. The tap comes with two flexible pipes 10mm end connectors to the tap but the other end has a female thread connector internal diameter 15mm, what threaded male connector do I need to get for my 15mm copper pipe ?
Also I'd ditch the rubber washers and replace with fiber ones. Or be very gentle when tightening up as with comp/bsp fittings it can easily damage the rubber washers.
You could just buy a pair of 10mm x 15mm monobloc flexis.
Two less joints to leak.
Many thanks for all the replies, and as suggested I will get a pair of 15mm compression x half inch iron for my flex hoses.
Dugit
No, you will not. You will get a pair of 10mm thread to fit in the tap x 15mm compression to fit on the copper flexis. ;)
