    Dismiss Notice
how would i make flexable render
Discussion in 'Plastering and Rendering' started by benwilliamson, 3 Jun 2010.
  1. benwilliamson
    benwilliamson
    23 May 2010
    24
    Thanks Received:
    Lincolnshire
    Country:
    timber house uk , all the inside is plastered no cracks apart from one wall i though would be fine without scrim (stupidity) outside kingspan or something the a galv mesh then flexible render, well hopefully any way,
    add sbr
    add pva
    add admix
    had a price for poly renders etc over 2.5k 100meters, don't really want to spend that
    any advice thanks alot ben
  2. Micilin
    Micilin
    6 Oct 2007
    2,883
    Thanks Received:
    308
    Bedfordshire
    Country:
    If you don't want to go for a poly render, then sbr in the render. This will give you a 'more flexible' render rather than a 'flexible 'render
    Remember though that you can use a fibreglass mesh instead of metal, which would give you a bit of money to spend on the poly. Also no need to paint th ecoloured render
  3. Sponsored Links
  4. external
    external
    10 Jan 2009
    241
    Thanks Received:
    27
    West Midlands
    Country:
    as micilin says all so you can put fibres in the mix to give some flex.
  5. benwilliamson
    benwilliamson
    23 May 2010
    24
    Thanks Received:
    Lincolnshire
    Country:
    what sort of quantity sbr in the mix, i did a swimming pool with sov chem k11 which is a tanking product looks like a bag of plaster then you add 50-50 water and sbr, it was for my dad and he wasn't bothered but the finish wasn't exactly good, it was kind of like plastering or rendering with plasterboard adhesive that didn't go off till the next day
    basicly impossible to work with
    however i think this is the way to go cheers lads
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
