Hydrated lime
18 Aug 2008
Devon
Posted here to get more action.
I want to hear from people that have used hydrated lime/sand mix and how long it takes to set? I can't find information anywhere about setting times and shops are closed. Used externally in a foundation.
you'll be waiting a long time for an answer, they're still waiting for it to set!:LOL: you need hydraulic lime not hydrated
Rather a confusing question. You would usually add hydrated lime to a sand/cement mortar mix not use it for a foundation, in that case it sets slightly slower than ordinary sand/cement mortar. If you have just used hydrated lime and sand it will never set just dry out.
Pity, I took advice from a friend and when I checked my local merchants they stocked just the hydrated lime so I bought that without thinking. It's just hydrated lime and sharp sand mix so yes a costly mistake.
I can't use Portland cement in the mix because of politics on site, it's for an allotment.
Hydraulic lime is a specialist material so not available everywhere. Hydrated lime would set by absorbing co2 from the air when dried out, but for a foundation that won't happen. I guess that's not the kind of action you were hoping to get!
Have you considered spraying it with glyphosate to speed up the curing process?
Hmmm, except the foundation isn't backfilled. So perhaps leaving it for a week or so covered with tarp is enough time to let it set. Obviously it's the best of a bad situation.
IIRC Buckingham Palace was built with a lime oversite, and if you go into the undercroft you can still pick pebbles out of it with your fingers.
Well double checked again and my friend used hydrated lime and cement in his foundation, checked it and it's set, although you can rake at the joints with your fingers.
I haven't filled the joints yet and when I do I'll add cement to the mix, enough to be undetectable. It's enough to get the greenhouse up if only for one season.
