Hydraulic Lime Mortar hard to work with
25 Jan 2019
I'm using hydraulic lime mortar (NHL) to (1:3 NHL:Sand) to install an air brick
However, it is very difficult to work with, its has the consistanct of wet sand and does not stick well.
Is there any thing I can add to make it more easy to use. I want it to stick together better and stick to the brick surface better
maybe you are mixing the stuff wrong - why not add a little washing up liquid and if the mix is too stiff then add a few drops of water.
make sure that the hole the brick is going into is well clean of any old mortar.
