Hyundai i20 windscreen washer jets are low
17 Apr 2007
2009 reg
I've had a look at them. I rinsed them off with warm water and brush but still quite low and more like a spray than a jet.
Stuck a pin to lift them a bit but the pin seem very loose inside.
Do these jet heads have nozzles in them that could have come loose and been pushed out by the water?
Usually each jet has two nozzles, which are adjustable. First thing, do they all spray the same? If they don't I remove the water feed pipe and blow compressed air back through them.
Try a heavier needle to adjust them?
John :)
You can get jets that spray, my Citroen and Peugeot had them , I liked them , others didn't.
