I’m a bit confused about part p.
The electrician came back the other day to fix the reverse polarity on the lighting circuit and before that he wired the new shower and pull switch in the bathroom, changed the old fuse board and put in a new Consumer Unit, sockets in the loft, and put power down to and in the garage. He will be sending the pass certificate in the post.
The system here is TT. The bonding in the bathroom when the electrician came was a bit of old thin earth wire raped around some of the pipes under the bath and on of them went under the floor and one of them was cut off hanging lose. The electrician has seen this and put in new earth bonding from the gas pipe and the water mains back to the CU and all old earth bonding was left in the same state as when he came.
I have some questions to ask.
What earth bonding should be in the bathroom to pass the part p?
Should the garage have its own earth rod or is it ok to run three core SWA cable and use one of the wires for the earth from the house CU back to the garage?
What bonding should be in the kitchen?
