When I moved into my current house I fitted a shower system with a thermostatic mixer bar and I installed a single impeller pump to boost the HW pressure. The existing shower (via the bath taps valve) was next to useless.
The CW pressure is very good - (possibly mains)
I connected a surrey flange from Wickes onto the hot water cylinder and i have used 22mm pipe all the way to the pump inlet. Pipe run is all curved except x1 90degree.
The now boosted HW from the pump goes into the wall and is connected to mixer bar using 15mm copper pipe. The cold water also goes into the wall with 15mm copper pipe and enters the shower valve at about 1 meter from floor level.
I have used x2 90degree 15mm - 3/4 compression fittings to connect the 15mm pipe to the shower mixer valve.
The problem is when I turn on the shower using the flow control on the shower valve - the pump does not engage.
The pump flow switch does work - i know this because if you jiggle the flexible hose which feeds the pump you can shock the pump flow switch and the pump starts... and when it starts up like this (i call this “jump starting”) it all works fine... until you turn the valve off!
It’s as if the shower valve is restricting the flow of the HW so the flow switch can’t detect any flow. - I suspect this because when I completely remove the shower valve and turn the HW on and off (using isolation valve) the pump operates correctly. - its only when i connect the shower valve all goes wrong.
My dad suggested that I fit a 1way shower check valve - this didn’t solve the problem.
My dad then suggested that I fit some sort of valve to reduce the CW pressure and therefore balance the flow into the shower valve??? - I haven’t tried this because i don’t know what im buying or if it would work... This is where you guys step in hopefully.
The pump itself is hard-wired with a fused spur (instead of the supplied 3-pin domestic plug).
My Fiance is not amused as apparently she can’t rinse conditioner out properly so any help is appreciated with thanks - Pazshower
