- Joined
- 15 Jul 2022
- Messages
- 59
- Reaction score
- 1
- Country
I have moved to a property that has ALL windows with trickle vents. On top of a wide ventilator in the kitchen and a smaller in the bathroom there is also an air brick in the living room for the old gas burner (removed long time ago).
This and the trickle vents on all 9 windows makes the draft like in a dog's shed. I think dog's shed is actually better.
I have already blocked the air brick but I have to address these trickle vents.
Before these windows are going to be replaced in a year or two I have to stop the draft.
Duct tape gives me mixed result because the small gap between the trickle vent cover plastic and windows frame is still leaking some air x9.
These Slotvent trickle vents cannot be removed. These are screwed in and I cannot remove the screw caps.
Should I just destroy these screw caps, remove the vents on both sides and duct tape holes on both sides and put the trickle vents back in
OR instead put some expanding foam into the holes in the window frame through the intake of the trickle vent?
Let me know what you think
