    Dismiss Notice
i need some rendering advice
Discussion in 'Plastering and Rendering' started by goateater, 12 Apr 2021.
  1. goateater
    goateater
    8 Sep 2010
    34
    Thanks Received:
    Nottinghamshire
    Country:
    hi all
    got a small concrete block wall that needs re-rendering (old render looks like it was removed years ago) it between 2 windows its only around 1.5 sq mts (1.3 mts X 1.25mts)
    it needs 30mm to bring it out level with the brick work either side of the windows
    here is my thoughts/plan
    1 basecoat of 15mm concrete (4 sand 1 cement) scarifer the surface
    fit 15mm pvc beading
    1 coat 15mm tarmac one coat render
    or should i go with more thinner coats of concrete/tarmac one coat ?
    I will need to build up the level so i can fit on the Pvc beading (10mm or 15 mm beading)
  2. Sponsored Links
  3. Notch7
    Notch7
    15 Sep 2017
    24,663
    Thanks Received:
    1,759
    S. Uplands
    Country:
    I'd be tempted to screw on strips of 18mm ply, then fit 12mm rendaboard.
  4. goateater
    goateater
    8 Sep 2010
    34
    Thanks Received:
    Nottinghamshire
    Country:
    would that hold up to the weather ?
    i get a lot of wind and rain that side of house
    just had a re-measure area is 147cm x 136 cm
    so would need a joint in the renderboard
    if i put up strips of marine ply, should i put insulation boards to fill the gap ?
    should i screw or glue the renderboard on to the marine ply ?
  5. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
