Hi all,
I've now more or less completed my garage rewire.
I've got SWA from non-rcd side of CU, which runs to the garage and terminates in a metal garage CU. garage CU has rcd and two mcbs, a socket radial and lighting circuits.
What i'm not clear on is where to do the I&T from, particularly IR and R1+R2 type tests, and how these get filled out on the installation forms.
My best thought was to regard the garage as a separate installation, and as such test and report based on readings taken at the garage CU. Additionally i'd do continuity and IR tests from the main cu, with the supply cable disconnected at the garage CU. Does this sound about right?
any pointers appreciated
slip
slip
