- Joined
- 6 May 2016
- Messages
- 48
- Reaction score
- 3
- Country
my outbuilding consists of a single skin brick wall, breather membrane, batten, and Celotex PL4000 insultation board (60mm foam insulation & 12mm platerboard) The ceiling is the same Pl4000 board screwed to the underneath of tapering roof joists. Joists are hollow and vented front and rear. Sitting on top of the joists the top deck is a simple water bonded 18mm plywood covered in felt.
The room heats up nicely, but within 30minutes of tuning off the heater the room becomes cold, uncomfortably so after about an hour.
Is this normal or am I outrageously under insulated? Before the build I contacted Celotex and they informed me that the boards they recommended would provide better insulation than a standard house.
Is this true, or was i lied to?
