I used Epoxy for the first time today
19 May 2007
It wasn't as bad as a lot of scare stories I'd heard on here. Fairly straight forward actually. I used Bal easy Epoxy. I rang Bal a few weeks ago and the techie people told me to use an epoxy grout float which is basically a very hard rubber float. It did the trick. They also reccomended I get an emulsyifying pad. Which is basically a very large scourer with much bigger gaps than a kitchen scourer. I experimented with a sponge to remove the excess off fist but it just smeared it all. The emulsyfing pad dipped and ringed out in warm water removed it straight away.
you definitely need some white spirit to clean your hands and the float though. I'd also recommend a well ventilated room.
