Also another point i forgot to mention is the ice is set to make ice (cubed/crushed) for any period of time like 8 hours or so, it starts to leak out of the ice despenser and melts into drip tray overflows and onto floor
Took the ice section out, its on a plug, took the cogs apart that turn the tray, tested micro - switches, they work, tested the compressor sort thing that has continuity also the element that cuts the ice has continuity, also PCB has a button on the bottom (reset maybe) put it all back togeather, been working spot on since saturday, dont know exactly what i did, but it works, and hasnt for months so looks like result
