Hi, i have just moved into a house that has a 5 year old Icon 23T boiler that hadn't been used in ages. The boiler was working fine for both water and heating for the first 48 hours until i noticed a leak. I thought the leak was simply coming from the cold input joint underneath but after running the boiler it seemed to get worse, then i found it dead
After checking it over i found water had run down through a perished seal on the gas pipe that runs through the tray that covers all the electronics and pipework underneath. The water had dripped into the main control panel and fried the main PCB, i found a blown fuse and resistor.
After messing about for ages evaluating all this and finding the correct resistor i successfully managed to swap it but everytime you go to ignition the 2A fuse would blow on the PCB. After more investigation i found the exhaust fan was also blown and this was causing the 2A to pop.
I have now changed the exhaust fan and when you open a hot water tap the fan spins up and it ignites but after 30 seconds only warm water comes out of the tap, then seems to go colder. Additionally and importantly i expect, when you turn up the temperature of the hot water the gas seems to splutter.
I have broken the timer clock investigating so can't test the heating until i find a new one but to have hot water would be like heaven as you can imagine after two weeks of trying to get this thing working.
I appreciate i need professional help but i can't afford it!
Any advice would be greatly appreciated.
