- Joined
- 31 Aug 2005
- Messages
- 4,420
- Reaction score
- 589
- Country
Okay i have a problem with my boiler:
IDEAL Combi120 (about 3 years old)
Power and Gas supply ok.
When i turn on the hot water the boiler goes into the warmup cycle the fan kicks in, then normally the boiler fires up (burner light comes on) and hey presto i have hot water few moments later.
The the boiler doesn't seem to be completing cycle of firing up:
Ive turned stat up set CH to on, and taken a look at the diagnostic LED's
Power to ignition = ON
Ignition Lockout = ON
CH = ON
Fan = ON
You can hear the fan power up and expect it to then spark up the burner but that doesn't happen, same for hot water. I can also feel the pump pumping the CH feed through the boiler.
Anyone out here know much about these and what it may be or how i fix it.
Otherwise it's time to go over a barrell with IDEAL i suppose.
The problem started last week, i haven't been using boiler so much as ive been away a bit, came back few weeks back and wasn't working, kept turning boiler on/off turning hot water on/off etc wondering if the pressure switch was stuck, eventually Burner light came on and hot water was ok.
Worked fine until i went away Saturday came back last night (Tuesday) and now it doesn't seem to work at all.
CH = ON
Fan = ON
