- Joined
- 23 Oct 2005
- Messages
- 1
- Reaction score
- 0
- Country
Hi
Have a problem my plumber isnt sure of !!
Have an ideal ff50 minimiser boiler connected to a megaflow hw cylinder. It is controlled by an acl drayton programmer, but occasionally when the kids have had a bath and the boiler needs to operate, the pump will keep running after the water is hot and will continually fire up the boiler even when the programmer is turned off !. It will continue to do this and will only stop if i turn off all the electrics and leave it overnight and then turn it all back on again
The central heating is controlled by a room stat and always works fine and under control
After the pump is a sunvic 2 way valve which its self is connected to a cylinder stat and after that a honeywell 2 way valve.
my plumber says the sunvic could be faulty but it never seems to be faulty when he is there !!
any thoughts anyone--apologies for poor non technical description above !!
