ideal classic lx ff - no pressure, rads empty
25 Jan 2009
Leicestershire
I am moving a radiator and have drained the system - ideal classic lx ff, no cylinder just a expansion tank in the loft. When I powered up the boiler it just fires up for a couple of minutes and the shuts down (pilot light goes out). Two of the radiators have no water in them and there is no pressure (no hissing or water when I try to bleed them). There are no pressure indicators on the boiler and as far as I can see no loops or valves. Just a stop cock under the sink (that is on) and a gate valve to the expansion valve in the loft (that is also on) - there is a little water in the bottom of the tank.
Can someone please advise me on what steps I have to do to re-pressurize the system and to get water flowing through the rads again. Thanks in anticipation for your help. Kes
Does the water in the FE tank cover the outlet hole? If not then as swb suggests. To help you fill the rads in the meantime, fill the FE with a bucket!! If you overfill, don't worry - it'll overflow and find it's own level.
I cannot believe the rapid response! just fantastic !! Thank you so much swb (Mike) and Swiddlers. The outlet hole is only partially covered, so I will fill with a bucket as per your suggestion and replace the float operated valve if this does the trick. Will keep you posted. Thanks again.
Thanks once again Mike and Swidders, your fault diagnosis was spot on. I partially filled up the HE Tank today and the pressure returned to the system. Boiler working fine now. I shall be talking for many months to come about what a great response I have had from you two guys. Just Brilliant !.
No probs - that's what we're here for.
You anywhere claybrook magna? Brother lives there
