Please help - we have a three year old Ideal Combi boiler. Last year a new control panel was fitted as LF (does this mean low flame?) kept showing then system would shut down - particularly when turning on hot water but sometimes when turning on central heating as well. There would be a banging noise when you pressed reset to get it working again..
Problem was fixed but one year on exactly the same thing is happening again so we have no hot water and we're having to press reset lots of times to get from LF to heating on...
British Gas say it must be that pressure in gas pipes leading to the boiler are too low but this system has been in place for over three years and why - when the same thing happened a year ago - did replacing control panel in the boiler sort it out??
The pressure reading they took in boiler was 16 (this doesn't mean much to me so no idea what it's measured in) when heating on - but then it falls right back when you turn hot water on - so not enough gas to work the boiler apparently..
We are desperate as to take up the floor and start again with gas pipes would be a huge huge job and why has it worked for 3 years and why does gas supply to cooker work fine? Is there anything else it could be and has anyone got any suggestions - please...
much appreciated...
much appreciated...
