Hi
I have recently bought a house.which has an Ideal icos he15 boiler. when i filled the system with water and put the gas on, everything was fine.
The hot water was working fine. then i tried the heating,
The radiators started heating up upstairs and the ' c ' is displayed which is good and the white burner neon is constant.
However the every 10 -15mins the white burner neon flashes then it sounds like the boiler switches off, then 5mins later it lights back up and the process is repeated.
What could this be?
I have a megaflow tank upstairs which is running at 1 bar, it may need to be running at 3 bar but would this affect the boiler operation like this?
i have no fault codes dispalyed and the boiler displays 0 at rest
Sean
What could this be?
Sean
