Hi All,
Yesterday I had air in one of my radiators, so I emptied the air. I have a sealed system, so as a result of bleeding the rad I had to top up the system to get pressure back.
an hour later the HE 15 attached to the system no longer comes on? No status lights or nothing. I have checked that all electricity is running to the HE 15 which it is, and I have also checked the switch on the front of the HE 15 is functioning correctly with a electrical screw driver which it is
The pump in the airing cupboard doesn't sound right either, instead of the usual constant drone of a pump going it's more like a jarring sound winding up then back down and the little light on the front gets dimmer as it winds up and then returns back to normal.
Any idea what could be wrong? Should the pump operate correctly even if the boiler is off? Thanks
