Ideal Icos He15 Gurgling/Banging, No Pressure Gauge/Filling Loop
rvp
26 Jan 2013
Manchester
Is it normal for a boiler not to have a pressure gauge and filling loop?
I wanted to top it up to see If that helps with the noise but I don't see any way of doing it.
Any ideas?
If the boiler is fed from a small tank ( usually in the loft), there will not be a pressure gauge
  • Thanks
Reactions: rvp
It could be an open-vented system, using a small, automatically topped up, tank in the loft. Check that tank, has around 3" of water in it - that the fill valve has not seized/stuck closed.
  • Thanks
Reactions: rvp
