- Joined
- 28 Dec 2022
- Messages
- 2
- Reaction score
- 0
- Country
Hi, I have a fault with an Ideal Icos HE18. It works fine when there is a demand for central heating. When I call for hot water or hot water and central heating simultaneously the boiler displays C and the burner LED blinks constantly. When you first send the demands to boiler it does fire for a short period before defaulting to the blinking LED. The boiler also never returns to standby ‘O’ mode. It always displays a C even when there is no demand from the Hive thermostat. I don’t believe it is a fault with the mid position valve as this has been replaced and required identically to the previous valve. The issue before having been we had hot water but no heating “stuck valve”.
The system is a Y Plan, with pump and mid position valve (Honeywell) located in the airing cupboard within the house, boiler is located in the garage outside. The programmer/thermostat is a dual channel Hive.
I’ve checked the wiring repeatedly and I’m convinced that it is correct. The hive is operating the controls correctly as it should do. You ask it for heating, the pump kicks in, you can hear the syncro on the three port and the boiler fires. Turn it off and it all goes off. Same process for hot water, but the boiler itself just doesn’t want to fire and it does the same when it has a demand for both.
Any help much appreciated. Before any one points it out, I have contacted an experienced gas engineer and he was scratching his head too.
