Ideal Isostar HE24 Boiler problems
24 Jul 2014
Middlesbrough
I have an Ideal Isostar HE24 Boiler installed under the warmfront scheme. I have been experiencing a worsening problem. The hot water initially runs hot then runs to cold. If you really turn down the flow rate it heats up to hot. This means that the shower won't work and it takes an age to run a bath. There is no issue on central heating (I think - its not been used since April). I contacted Ideal and they want me to arrange an out of warranty call out at a cost of £275. I've seen a lot of discussions about faulty PCB's but Ideal say its probably a problem the domestic hot water thermistor or a valve. Any body any experience to share that could help me resolve this problem?
If its a Isar its well out off warranty. Logics replaced them 5-6 years ago now.
Plus Isar was the warmfront boiler of choice.
Would recommend the Ideal repair or get a local gasman out. Possible Scaled plate heat exchanger as you live in a hard water area
It will be hot to begin with because of the preheat function
We usually just swap out the plate with a new one. Clean the old one and leave it with you for when the new one scales and swap em again and so on... though saying that the Isar will have selfdestructed by the time the new plate requires swaping over
:P :P
Have you spoken to the rgi that services it (hope for your sake you have had a yearly service).
