ideal isar he24
16 Nov 2009
Yorkshire
hi there i have just installed a ideal isar he24 boiler the central heating part works fine but hot water is not working . i can turn the tap on for hot water but there is no flow from the boiler ....can anyone help i am a plumber but not a heating engineer...
G
gassafeman
It will be..... broken. I have to congratulate Ideal on the fact its made it onto the wall. You cant ask for more than that.... and I mean by that... it will sit as an ornament. It wont do much else.
Why do Trolls challenge our intelligence. :?:
Paul.
25 Aug 2008
Have you by any chance left a transit plug in the boiler?? :rolleyes: :LOL:
16 Nov 2009
Yorkshire
hi there thanks for your replys ....the transit plugs were removed ..
but tonight i turned everthing back on & the water flowed no problem
only thing i can put it down to is a air lock.its wery weird
but as you say it is an ideal isar he24 ????? :eek:
25 Aug 2008
The new isar derivative with brass hydroblock and grundfos pump is alright!!
19 Jan 2007
Kent
I went to a new Isar with the same problem,the installer swore blind he'd removed the transit plugs,guess what i found on the hot outlet?
