Ideal Istor cylinder thermistor
11 Dec 2010
Hi
Can somebody explain the function of the thermistor on the unvented cylinder on this model and what symptoms would be seen if this fell out or had failed?
many thanks!
Its a temperature sensor.
If it fell out then the system would continue to heat the cylinder when it was already up to the set temperature.
If its failed that would all depend on the type of failure, OC, SC or just wrong resistance.
Why do you ask?
Tony Glazier
When engineer last out this got knocked out and although he put it back in it looks to me like the cylinder is overheating - the insulation is puckering/melting a bit....
thoughts?
No - it's not a joke - I'm just asking for some info/advice on this boiler/cylinder.
