ideal logic 30+ combi ignition lockout
5 Aug 2014
Cheshire
hi guys,
ive had this boiler about 40 days now.
when it was installed we found two of the radiators needed bleeding but wont bleed (valve stuck)
havent sorted them yet but they do still heat.
anyway the boiler will fire but every now and then it says ignition lockout. i can reset it and all is fine for a while.
for example heating was on when i started running a bath it locked out again but this time with some load vibration from the boiler.
then quick reset abit of vibration again and all fired up again.
any ideas appreciated.
Installer is coming out on Monday but I wanted to check if this issue could be caused by air from the radiators I can't bleed.
