- Joined
- 20 Jan 2010
- Messages
- 9
- Reaction score
- 0
- Country
I've recently moved into a new place with an Ideal Logic Combi 30+. The boiler was brand new and works great. However, once the set temp on the room thermostat has been met, the boiler will constantly cycle on and off, only staying lit for a matter of seconds, and then when it's almost completed it standby routine it fires back up again, once again only staying lit for a matter of seconds. Is this normal behaviour?
If I increase the temp on the thermostat it will stay lit until that temp has been reached, so it doesn't cycle until it's reached the set temp.
The system consists of all underfloor heating downstairs and two rads upstairs. One has a TRV and the other in the bathroom does not. All rad valves are fully open and the TRV is set to 4 out of 5.
The room stat (downstairs) is the wireless Ideal PRT3 model.
Any help would be much appreciated, as I'm slightly worried the constant cycling is going to lead to a premature failure of something...
