My boiler decided to stop working last night.
Is there Anyone that can offer some advice on this combi boiler, even better someone local that can do the job?!
The boiler won't do anything but there are no lockout lights.
The pump appears to run when there's demand but just gets hot, it's pretty noisy too.
It doesn't attempt to fire at all though.
Had a fiddle and have bled the system and also the pump, that made the pump quieter so there's definitely water in it. (I got a face full!) The pump does get quite hot.
Water doesn't appear to be circulating around the boiler, if it does it pushes out a pin that hits a micro switch telling all is well with the flow and the boiler starts. This isn't happening.
I've removed the micro switch so the pin is visible, when there is demand the pump makes a noise but the pin doesn't pop out like it should so this tells me there is no flow.
If I press the micro switch in myself the boiler fires into life but then makes kettle like banging noises, I think this is due to the heat exchanger being empty.
So I think it's either a duff pump, blocked heat exchanger or posibly an airlock - possibly caused by me not bleeding the radiators in time, they have been a bit noisy.
So, can anyone advise how I can remove the airlock if there is one?
Many thanks
Many thanks
