IDEAL Push fit connectors
11 Feb 2007
Yorkshire
I've seen these on screwfix and they look good with good reviews.
I'm putting some downlights in, and the exiting rose wiring comes through a very small hole on the side of the joist, so 'ideally' I don't want to cut a big hole to get a standard juntion box into the ceiling void, thus these little things look just right.
Can't see anywhere though if they can be used 'stand alone', i.e. not inside an enclosure (wagobox) ???
The floor void is uninsulated, also I don't want to take up the flooring above to gain access.
thanks in advance!
I have never used Ideal connectors, but they appear to be similar to Wago (I see they also are selling those horrible wire nuts :( )
http://www.screwfix.com/p/ideal-twister-lt-340-twist-on-wire-connectors-pack-of-100/85465 .
But I digress. Any connections must be inside an enclosure and all cables entering the enclosure must have strain relief provided by the enclosure's design.
Alternative strain relief - the cables and the enclosure can be fixed to backgrounds.
So you'll also need an enclosure, I don't see one in the ideal range, so may be Wago. But then, why not use Wago connectors too? Up to you…….
thanks, if a jobs worth doing.....
