I have 4 identical toilets (which have the Ideal Standard SV92667 Flush Valve) all of which have all had their share of problems over the years due to shoddy installation and wear and tear.
Over time, I have removed the cisterns.. Installed new close couple screws (Which were sticks of rust) swapped the fill valves with Fluidmaster and replaced all of seals and they are perfect.. Except the last one I did this weekend.
Once I re-assembled everything I flushed the toilet and noticed water dribbling down the pan.. This carried on a for a few seconds whilst the cistern filled and once the level got to a point (where there was pressure on the seal) it stopped leaking.
The other 3 toilets don't do this, so I assumed there was something wrong with the cistern and not the valve.
So I swapped the flush valve over with another toilet and the fault followed the valve.. I moved it again, and again it followed the valve.
This would lead you to think the flush valve seal was at fault, but its brand new and perfect... Since the valve itself is the definition of simplicity and just drops the seal into the hole using gravity and then water pressure, I can't see how that could be at fault.. But something is wrong.
I thought about leaving it as it doesn't seem to leak once full.. But I closed off the inlet and left it for 3 days and the cistern totally drained.. So its still leaking a tiny amount.. Perhaps not enough to worry, but it bothers me.
Does anyone have any experience with the Ideal Standard flush valves who might have an idea of how such a leak could happen? I guess its possible its just a faulty seal? I can't see how but its possible I guess.
I look forwards to your thoughts.
