Hi All,
I'd like some help and maybe ideas as to what to do with a small concreted walking area. It was ok before, but the concrete did look a bit ugly and was uneven and sloping quite badly.
I've added some pictures to show what it currently looks like. It's about approx 2.4 across, and 3ft tapering out to about 3.2ft wide, so the actual stepping area is only going to be 1-2 steps across the 3ft gap.
I've bolted 2 bits of wood to either end to the height of the steps and garage floor level so have a good solid fenced off area all around, and I've hammer drilled it down so that the shallowest below the top level of this fence is about 3.8, down to the deepest point being at around 70mm.
So my dilemma. What to fill this in with.
Preferred options so far are:
1. Gravel, I was thinking of using white to match stones we have in the garden borders:
http://www.homebase.co.uk/en/homebaseuk/pearl-spar-grade-11-maxi-bags-284201
Only problem with this is that I've read gravel on concrete can get dangerous as the grinding rounds off the gravel and makes it problematic under foot. It won't get a lot of footfall though, and the contact area will be very small indeed with only 1-2 paces ever hitting the area.
2. To offset the underfoot gravel issue, 4 450 x 450 paving slabs with 120mm in between and 220ish at front and back. But to do this would have to raise part of the sloped area to hold the slabs level so would have to concrete a bit underneath. What issues could this cause? Design below:
3. Concrete the whole area again but level and with some decorative concrete, perhaps coloured concrete if possible.
4. Any other ideas?
Thanks,
Wialli
4. Any other ideas?
Thanks,
Wialli
