- Joined
- 27 Jan 2008
- Messages
- 29,642
- Reaction score
- 3,665
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
The party line I remember, but not sure exactly how wired, but know with parents house an electrician connected the main house earth to the party line earth wire which was around 3 mm² bare copper, and was clipped to outside of house with a steel earth rod.
I realised when I came to work on the house there was no earth, but I also remember as a young lad blowing the fuse when I shorted line to earth (in error of course) so at one point there must have been an earth, but when I came to work on the house could find no sign of one.
The old Wylex fuse box had been changed to a consumer unit when the wet room was done, so the earth could have been lost then, but could not find any sign of an earth which had been disconnected.
We should I know has an EICR every 10 years or change of occupant which ever sooner, but I have never done one on my own house, yes tested some section which I have worked on, but not methodically worked through the house testing all electrical items.
There was a report when we bought this house, but it said there was an old disused fuse box in the ceiling void, it was in fact the main board for the house, the consumer unit only covered the lower floor which had been a garage and is now a granny flat.
This is of course the problem, when some one does a proper EICR he/she may find things which look OK, but test out as faulty, this house had a borrowed neutral on the stairs lighting, and not because only 2 core cable used, the neutrals were all in the 4 gang switch, some one had simply selected the wrong one, so easy to fix. Found when moving to all RCBO protection.
