What on earth leads you to think it is either? It is a statement. I will make this as simple as I possibly can: The lights you suggest are intended for non-domestic installations. Which part of that do you do you consider is incorrect?I mistakenly thought that this:
was a criticism of me suggesting that lights "intended for non-domestic installations" could be used in a domestic environment, not an agreement.At the slightest mention of downlighters were are treated to your cut&paste of various light fittings intended for non-domestic installations.
The lights you suggest are intended for non-domestic installations. Which part of that do you do you consider is incorrect?I mistakenly thought that it was OK to use them in a domestic environment even if the maker intends them for use elsewhere, in the same way that it's OK to use tools for DIY even if the maker intends them for professional use.
I am pretty sure I said something along the lines of 'The lights you suggest are intended for non-domestic installations'. I have also said 'I can't see any reason why you can't use them for domestic use.'It would be a great help to me if you could list what sorts of items intended for professional or non-domestic use are OK to use in a non-professional or domestic setting, and which are not, since you clearly have a lot of knowledge in this area, and I clearly don't get it at all.
Your confusion appears to arise from trying to understand what I mean by something I haven't said. I have no idea why you are getting hung up on this point.
Your confusion appears to arise from trying to understand what I mean by something I haven't said. I have no idea why you are getting hung up on this point.Again, I would appreciate an explanation from you of what kitchen items, e.g. pans, knives, ingredients etc I should use, even if the makers intend them for non-domestic use, and which I should not, because obviously I have been going terribly wrong by considering what things do rather than taking notice of the market the maker thinks he should focus on.
My apologies - I mistakenly thought that as some people like [different things]Unobtrusive: probably, though that doesn't necessarily make them attractive. Whatever.
I said:
You appear to agree with me on this point.appearance is clearly a personal opinion
If it requires any new fixed cabling, it will not be OK unless you notify your BCO. You'd be best getting an electrian in. I'm not sure what other point you are trying to make.Would it be OK if I removed the lights and put in a twin 6' fluorescent strip which uses only 140W?
Indeed. What is your point?That will be the room with 0.78 lights per m², will it, compared to mine with 0.46 and Steve's with 0.12?
You seem to be struggling with some basic concepts here which I am sure you are well aware of.My apologies - I mistakenly thought that when you agreed that "of course" absolute wattage is not the point you were being truthful.
'efficiency' is the how well power can be converted for one form (e.g. from electricity to light). Now we don't know the absolute value of the optical power, but we do know in these cases it is adequate to satisfactorily light the rooms. Hence, in this case, efficiency is inversely proportional to input power and so something requiring x10 more input power is x10 less efficient.
I have made no statement about what is 'good' and 'bad'. I'm just basing it on your criteria. You have previously said:So 1 light for every 1.28m² and 2.35W/m² good, 1 light for every 8.5m² and 3.05W/m² bad.
In the scenario given, 2.34W/m² was sufficient to light a room. This, according to you, is 'inefficient'. In the scenarios using the commercial lights, the power required was 3.05 - 24W/m². This, according to you is 'efficient'. I think I must of been ill the day they taught 'using more power to do the same thing is more efficient' so you'll need to explain this to me.MR16 LED lamps consume very little, but they are still inefficient at lighting up rooms
I don't know. Maybe you should ask somebody has experience of these, rather than somebody who claims to have no experience of these.Could you light a 17m² room with 2 of them?Have you ever looked at LED lamps? The 'MR' part has very little relevance. The beam angle is dominated by the internal reflector within the LED. The ones that use higher-current chips usually have additional per-chip reflectors, but this is entirely independent of the MR16 format. Some even claim beam angles of 120 degrees, although I have no experience of these. You may want to google some images of LED MR16 bulbs.
