Igniter on grill not working
30 Jun 2011
Kent
The ignitor on our grill has started playing up. It doesnt 'spark' when the grill is off, but when you manually light the gas, it instantly starts sparking again when you press the button.
Just wondering if this is a common problem that can be easily rectified? I'm assuming the flow of flame is carrying the electricity better, so would bending the ignitor closer to the roof of the grill work??
Or do i need to look at replacing something?
If there is a time delay between the flame initiation and the sparker working again I'd say it has to do with sparker being heated.
You might be able to confirm this thermal link with a cigarette lighter.
But,
"The piezoeffect in piezoceramics is "trained", so unfortunately their high sensitivity degrades over time. The degradation is highly correlated with temperature. "
Yep, warming it up with a cigarette lighter it works fine, so appears it is temperature related...
So... how do i fix it?!
I think it is shot. How much for a new part vs. how much for a new grill?
Well, replacing the grill isnt an option...
Any ideas what the part i'm looking for might be (and what it's called??)
Is it just the white nub with the metal bit sticking out, or do I need to replace the connection etc?
I think the smallest assembly you can replace and still be reasonably sure you are fixing it, is the knob you press and the white porcelain high voltage insulator with center electrode.
See if the maker will supply you with an exploded view or parts list or just ask a local distributor for your grill how to buy a new ignitor.
The idea is to make the cost of the part so expensive that you are on the fence about repairing the grill or replacing it. The grill maker knows how you buyers will respond on average, and DIYers are to be punished because they are 'a threat to the free market' or some such BS.
