IKEA corner cabinet trim column
12 Feb 2015
Surrey
I am installing a U shaped kitchen with the hob/oven at the centre as can be seen on the second photograph.
As can be seen on the first photo, there is a base drawers unit next to a base corner unit (the unit with the loose cables).
At the corner between those two base units there will be a gap which I presume I would need to cover with something, but I cannot find it online on IKEA. I do not know the name and my searches have failed.
What should I be looking for?
ALSO: on the base corner units, which way do I put the door, for example should the door swing open towards the drawers, in which case I can use ordinary 110 degree hinges, or should it swing wide open towards the oven, in which case I would need some special hinges? But then it would bump into the oven handles...
