Hi
I'm hoping an expert here will be able to help diagnose or pinpoint what the problem here is.
As titled, our immersion heater is not heating up the water. When we turn on the switch, there is a light, which indicates that power is going through. The fuse at the main box serving this supply seems to be intact, so that points towards maybe the thermostat or heating elements may be up the creek?
1. Is it worth changing the switch (although it lights up), replacing it with another (20A?) unit, or am I wasting time here?
2. If the element has gone, I've read that this usually trips the fuse box. This hasn't happened as far as I'm aware.
3. If I need to someone out, I guess I'll need to call an electrician? How much am I looking at here?
Would appreciate if someone can shed some light.
Thanks for any advice.
