just tested the resistance (with the power off again) between the L and N terminals and it read 28 - is that really bad? does this mean also the element has failed? why would this be? scale...?? wear and tear??
whilst i'm being dumb, one last query, the thermostat obviously of course heats up and then heats the element by conduction which in turn then heats the water in the cylinder.
TBH I doubt it. It might mean that you have a 2kW element. Is there a label on the cover, or a value stamped into the brass boss?just tested the resistance (with the power off again) between the L and N terminals and it read 28 - is that really bad? does this mean also the element has failed?
With the power off, if you bypass the thermerstat, then put the cover back and re-energise, does the water get hot?why would this be? scale...?? wear and tear??
Well, 28 Ohms would be the expected resistance of a 2kW element, would it not?why would it mean I have a 2kw element?
With the power off, remove both of the wires from the 'stat, and connect them together using a connector block.i'm not sure what you mean? bypass the thermostat then re-energise, what do you mean exactly? sorry!With the power off, if you bypass the thermerstat, then put the cover back and re-energise, does the water get hot?
According to.... ?yes i agree, about 26-28 ohms would be correct. but my heater is 3kw!
How old is your meter battery?i'll test it again, bear with me!
Wrong. Hence the question "does the water heat up?".btw what you are saying about the wires together - this is to prove the thermostat has failed right?
heater has 3KW on the cover sticker.
You don't need to apologise, but an explanation would be nice.I have to apologise, I have a 2KW heater
