topWhere is the immersion on the cylinder? Top, middle or bottom (no it’s not strike it lucky)?
So likely a 27” one, I’d personally measure the temp first, then you’ll know whether to adjust or if immersion has failed.
Measure at the taps or in the cylinder somehow?So likely a 27” one, I’d personally measure the temp first, then you’ll know whether to adjust or if immersion has failed.
Is 55 degrees sufficient to stop legionella? I have seen various numbers, but most commonly 60-65Hot water should only be set to 55C otherwise the hot water will scald.
Competent plumbers can wire up heating systems. But many are not competent.
Only a very few electricians can confidently wire up heating systems.
What is needed depends on what has already been done. It is possible it hardly needs anything to be done.
Even electrically heated water costs depend on your water useage. A three minute shower is only about 90p. A bath about £4. But daily heat loss about £1 from the cylinder even if all HW pipes are lagged.
At the tap, which should be approx 50 degrees in abut 30 seconds.Measure at the taps or in the cylinder somehow?
as water in a cylinder is either fresh, or stored for hours, I am quite happy with a middle temp of 50C20° or less – Legionella survives, but in a dormant state
20° to 45° – Legionella will grow rapidly
50° – Most Legionella bacteria will die within hours
60° – Most Legionella will die within minutes
70° – All Legionella bacteria will die instantly
But setting hot water at 55C should result in then dying and not multiplying. And it will not scald you too quickly.
Do you have a source for this? I am seeing 60 degrees is necessary.20° or less – Legionella survives, but in a dormant state
Hi @Agile , just checking - are the contact details in your profile up to date? I have tried to contact you about attending to this, and I don't seem to be able to send you a private message. ThanksHot water should only be set to 55C otherwise the hot water will scald.
I just checked out the right thermostat this time, and was shocked to see it was set to 55 degrees. Is it normal for the HW to be set to 55 degrees, yet when I run the hot tap to the hottest I can't comfortably wash my hands in it? (For the bathroom tap which has no mixer).
I know it probably won't make a massive difference, as we've had it set to 55 degrees for years with no problems, but I would like to get it optimal now that I have cleared all the crap out the way to access the thermostat.
