sorry but i need to clear something up for piece of mind!!
an immersion heater has its own radial circuit from the cinsumer unit, usually rated at 16amps (mcb) - twin and earth runs from this to a double pole-switched socket near the heater? correct? in my socket i have a cartridge fuse, rated at 13amps. in a book i have been reading it says the twin and earth should run to a 21amp double pole switch!!! well mine is only 13amp!! and from this point a 21amp heat-proof flex is run to the immersion heater. well i have a 2.5 mm flex from the socket to the heater, but IF this is 21amp (as standard) then how comes it doesn't blow as my socket is rated at just 13amps!!! i am a bit confused!! probably just being silly though but would like some help!!...??
