I replaced the stat, and the problem remains - new stat is "working" as I can hear it click on and off as the water in the tank cools.. It's a dual immersion, and on the old stat, the "bath" setting did not heat any water. Wall switch seems to be wired correctly. Bath setting now overheating the water as well!
Wondering if the brown 'live' to immersion should attach first to the OverHeating stat, then on to the thermostat, as it now does ?
A previous thread suggested that the stat may need to be rotated by 180 degrees, but not in this case - seems to be clicking at approx. the correct temperature.
Any ideas ? and thanks in advance
