Impaq Contact-W
7 Dec 2014
Hi
How do I put this device into learn mode, so the panel can see it?
On the PIR's there a learn button.
contact-w and shocks have a learn jumper at the side of the unit need good eyesight but it is labelled.
short the learn pins and add the battery, start the learn process on the panel.
WOW found it.
I also found it on the instructions, but the font is less than 1mm.
Would it be acceptable to take the jumper off the reed enable/disable and use it to short out the 'learn' terminals?
Then once that done put the jumper back where I want it?
