A question, what asbestos will be in this?
Can't it be wet, wear a mask and remove it (all done outside) into a bag that's then disposed off at the council amenity site into the correct container?
Probably just the rope seal on the door, if it has re-wireable fuses (unlikely at 200A) there will also be an asbestos flash guard inside the holder. I assume this unit is not in use any more but if the asbestos is removed the unit must no be put back into electrical service.
