The flow rate through the rad is the same as that through the connected pipes, it's only the velocity which reduces. This will be the same whatever size of pipe is used and will have been taken into account when the rad was designed.I agree with D_Hailsham that the 8mm pipework itself should not block (although it has 90 degree elbows in where it pops out of the wall to feed the downstairs rads) as the flow rate is high (the valves to the lounge rad are fully open). But once the water enters a big rad it will slow down a lot and deposits may well drop (which seems to me to be better than going back to the boiler).
I had the same problem when the boiler was replaced. So I contacted Fernox as the installer suggested putting the filter on the flow before the pump. I got this reply:access to the boiler return is very difficult which is why I have proposed putting a filter before the pump
The risk is due to the isolation valves, which if shut would create a potentially dangerous situation. The TF-1 will not block with sludge so as to obstruct the flow.
Adrian Dyer
Fernox Technical Services
