C
cantaloup63
If one turns the gas off at the mains, then is it legal for a diy'er to decommission all in-house appliances (boiler, fire, hob)?
All gas installations have been done by registered pro's (other than wet work carried out by me - I had to justify that CC course somehowWhat do you mean? Why are you asking?
It's all gone now and been replaced by an RGI. I was just wondering if what I did was OK, since I might at some point in the future be asked by a friend to help them decommission and I want to know that the regs are. Does turning off the gas at the meter constitute an appropriate degree of "sealing" off subsequent pipework? One is making a huge assumption that the valve actually worksAs long as the part of the system that you are not working on has been suitably capped/ sealed off by an RGI then you can do whatever you like to the pipework which will no longer carry gas, same for the appliances.... I assume that you will be ripping out a boiler or a fire and a bit of pipework..
I think that "The meter will have to be fitted with a disc or cap end.
...........or are you saying turning the ECV off would be acceptable?![]()
they simply turn the valve off
They dothey simply turn the valve off
No they don't dude...
not in gas - I'll leave that to NazHey cantiealoope , thought you did a course.![]()
Well, in my experience (and my next door neighbour is a National Grid engineer), they'll shove a disc on anything...
