Indesit Cooker Ser' No,FIDM201X
19 Mar 2009
Norfolk
Badly need Wiring Circuit Diagram for my 3yr old cooker. Have tried Makers to buy one but they want to send Service Engineer at cost of £99.Or for me to sign up for £50 a year insurance deal. Thanks, Hut27
you wont get one ,rare as rocking horse sh??.wot do you want to know anyway :?:
The main oven switch when used on Position 2 brought on LIGHT,FAN,HEAT. Recently it stopped doing this (after tripping MCB) Now only get LIGHT,and FAN, no heat. Turn to Position 3 and as intended Get HEAT,LIGHT.. I obtained new Multi position Switch from makers and it made no difference. There is probably some relay or stat' at fault and I would appreciate some help.
I would guess the fan element has gone,and position 3 is conventional oven using top and bottom elements .The fan element is behind the back panel.
Thanks for reply, According to my users handbook there is no rear heat Element. The Fan does operate on Switch Position 4( used for de-frost) again according to book.
My info shows a fan element,does the rear panel in the oven have screws to remove it ,if so there will be an element behind there.
Hello Again, I can see 4 screws inside oven, there is also a light and a Sensor Phial clipped on the top LH side. You any idea of what the Part no is I should order. I imagine I could thread sensor phial back through entry hole in back plate. I really need the part I need in my hot little hand as I dont want to have to be without use of cooker. Thanks , Hut27.
Remove the back panel and have a look at the element,it might be visibly blown.If not remove the element and test it.
