Indesit dif04
29 Oct 2008
Devon
Our Indesit has just started a problem where you can turn it on, it beeps, start to hear it filling then it stops and does nothing. If I open the door, then same LEDs are on but if I try and change the program it beeps a couple of times and there is some water in there and I have to hold the power button to turn it off. At which point it then drains.
Turn it back on and the same happens. It's obviously draining and filling.
Edit. I have just taken the spray arm out, run some water through it, opened up the salt reservoir which was full of water but we've never added salt to it, turned it back on and it does sound as though it's progressed a bit further. It sounded to be filling a bit more, I've opened the door, it stopped and then carried on when I closed it.
Spoke to soon doesn't se.to be getting any further. The flap for the tablet hasn't opened and there is a faint electrical noise but nothing happening
