INDESIT DIF04UK DISHWASHER - On/Off button defunct
23 Jul 2008
Suffolk
My DIF04UK dishwasher has developed a fault whereby pressing the On/Off button has no effect on the appliance.
I've dismantled the door and checked the visible wiring, eg for breakages around the door hinge area and in the vicinity of the retaining bar but can't find a problem here.
Its still possible to use the machine as pressing "P" button once turns it on but pressing it repeatedly does not step it through all the wash cycle options. However, once started the machine seems to complete a wash cycle OK.
Any suggestions as to whether I should anticipate having to replace the LED Card, the Control Module, or something else entirely?
The LED Card would appear to be easy to change as its within the door, but is the Control Module that easy to replace and can it be done with the machine still in situ?
Any pearls of Indesit wisdom would be very gratefully received!
Davros
Change the led card that's the one that's faulty. It's the one on the top of the door.
Obtaining the replacement LED card took quite a while and I've only just fitted it. The machine has not yet completed a full cycle but the On/Off button now works and repeated depressions of the P button steps through all the available wash options.
Many thanks rocks1!
Davros
hi all got same problem as above is LED CARD THE SAME AS A SMART CARD AND IF SO WHERE DOES IT GO
CHEERS CHRIS
No , led display is on the top left hand side of the door.
thanks Rocks1 can you tell me where i get LED card
please
cheers chris
thanks again
its stared flashing on/off button and eco button
is that still same fault cheers chris
you poss got water in the base of dishwasher ,tip it forward see if water comes out.
thanks again Rocks1 empty water out by tilting it forward switch it on to run progarm goes for 5 mins n stops with the 4th light flashing any help would be great
That's error fo8. Check the thermistor is attached on the dispenser , it's a little square block, remove the other door then consol panel then you will see it
if its a wee brown block under the catch its still connected run it again its now flashing off/on and eco button cheers chris
You gota leak if Eco is flashing. Tip it up again check bottom spray arm nut , salt nut. It's setting off the float again. The sensor on the dispenser is white not brown , it's got 2 black wires running off it to the pcb.
thanks again cant see any black wire only brown not sure about salt nut where is that cheers chris
