hi there, got a problem with our tumble dryer. the belt broke on it so i have replaced it and put the machine back together and now it trips out the circuit as soon as it is turned on. i cant find any loose wires and it is the correct belt, any ideas?
Check the wires are not rubbing at the hole that goes from the heater to the motor. It's on the back right as you look at the mc also check heater is not damaged.
