indesit problem helpppppppppppppp!
28 May 2009
Essex
Got an indesit washing machine purchased in australia a model w63t.Came home today and the programme dial switch thingy is clicking and if you turn the machine off and reset it it just clicks and returns to the finish position .Also :( sometimes just clicks around and around and doesnt stop.Its been a great machine so please any help appreciated. thankyou.
When the dial clicks round one of the lights flashes on and off in a sequence
count the flashes between pauses and this will give you an error code which can be useful.
Rocks1 has posted the error codes for indesit machines dozens of times on this forum
error codes indesit number of flashes
1=short circuit triac
2=motor jammed check plugs
3=ntc open/short circuit
4=p/switch jammed on empty
5=p/switch jammed on full
6=prog selector managment error
7=heater relay stuck
8=heater relay cant be activated(common on new boards try tapping relays)
9=incompatable eprom
10=pswitch not sensing correctly
11=pump cant be activated
12= commuication error
13=dryer fan does not work dryer ntc faulty
14=dryer ellement
15=dryer ellemnt not working dryer relay on pcb probable
no flashes but door lock led lit but fails 2 cstart check door lock motor heater and associated connections
were there is a lcd display all codes will be preceeded with an f except h20 =not filling
