Morning all
I've had a few issues with the above dryer
First of all the machine wasn't turning off when I pressed the stop start button , then the machine wasn't turning on when I pressed the button
I opened up the machine and can see the Jockey pulley has cracked so I've ordered a new one as this explains why it wasn't turning
I took the stop start switch off and I connected the 2 wires together and the machine starts up but obviously doesn't turn
I just need to know if it's the switch or the relay.
When you press the switch it just makes a noise then stops so it doesn't appear to be latching.
Cheers
Cheers
